Page 5 of 7 FirstFirst 1234567 LastLast
Results 53 to 65 of 80
  1. #53
    Naples, Fl
    Aug 2008
    Ridgecrest, CA
    Under the install menu I changed it from EAC to Media+EAC we will see what happens...
    So there is nothing published about the SP in these units?
    Thanks for everyones help...I cant be the only one when this problem in my town... they have installed others too..
    Maybe someone from Carrier is in order to fix it properly..I wonder what that costs
  3. #55
    Naples, Fl
    Quote Originally Posted by MPNX2 View Post
    Your cost should be nothing. Carrier will just show your contractor his design flaws.
  4. #56
    As above.
    Carrier will just let them know what needs changed.
    Carrier will not tell you either.
    You are not their customer, the contractor is. So don't take it personal.
  5. #57
    Aug 2008
    Ridgecrest, CA
    As above.
    I will call Carrier but accroding to the webstie they are now closed... So I will call Tuesday.
    As long as its fixed properly thats fine.
    I changed the Filter uder the Accessories menu to media but no change yet..
  6. #58
    Naples, Fl
    Changing the filter type isn't what you need to do. I am sorry but I will need to check to tell you what you need to do.
  7. #59
    Aug 2008
    Ridgecrest, CA
    Quote Originally Posted by adrianf View Post
    The control is now displaying the filter notification....
  8. #60
    Your static is too high. Its going to do that till your duct issues are taken care of.
  9. #61
    Wow,the contractor needs some assistance.If the coils are not mated to the furnace as shown in the install manual,that adds a lot of static.
    Can't see the pics well enough,at the beach,wireless only connects outside and it's sunny here.
    Have you GC call Carrier if the contractor won't,as well as calling yourself.
  10. #62
    Houston,Tx.
    Blew it up some don't know if it's enough to help any.
  11. #63
    Aug 2008
    Ridgecrest, CA
    Some added info....
    Along with my blueprints I found my Certification on Compliance...
    It has the HAVC info on it from the acrhitect.
    Total Heating Load (Btu/hr)
    Furnace 71967
    Sensible Cooling Load (Btu/hr)
    ACSplit 34794
    Design Cooling Capacity (Btu/hr)
    AcSplit 42387
    Maybe that helps with the sizing
  12. #64
    Is that for just one area of the house, or the whole house.
    That load doesn't call for 2-5 ton units.
  13. #65
    Aug 2008
    Ridgecrest, CA
    Thats the whole home.....with those numbers what kind of tonnage should I be using?
    One unit just gave me a "System Malfunction" on the control. I looked at the faults and it says "Possible Frozen Coil-Active".
    Would running a zone unoccupied cause this? I havent seen this one before and the unit of course will not run... I dont know what the tech did to cuase this...so now half of my house is not working....
