Results 1 to 13 of 18
    regina saskatchewan
    Capacitor voltage?
    Working on a a/c unit(220volt).found a bad run capacitor.The original capacitor is a 35uf-440vac.replaced it with a 35uf-370vac(thats all I could find in-town).will going from a 440 to a 370 vac rating cause any problems?Thanks in advance!
    Artificial Intelligence is no match for Natural Stupidity
    Aug 2008
    Fremont, Ca
    What is the voltage of the system you are working on?
    regina saskatchewan
    220 volts
    Aug 2008
    Fremont, Ca
    You'll be just fine!
    Oct 2007
    Broward County, FL.
    If the compressor calls for a 35x440 , use a 35x440. You can replace a 370 with a 440 but not the other way around.
    regina saskatchewan
    Thanks for the replies guys.It might be a week till I am able to get the correct capacitor.Is the compressor safe till then?
    Yuma, Arizona
    The capacitor is unsafe.
    We've all installed a 370 volt in place of a 440 volt run cap but I've never
    done it with intentions of leaving it that way for longer than a day at the
    most. Your compromising not only safety but the equipment also.
    **NOT RECOMMENDED**
    Rapid City, SD
    Tell the supply houses to only carry 440 caps. Much safer bet that way.
    I think there might be some over reacting... as far as a safety issue... beh, it's not going to kill anyone unless someone is sitting there staring at the cap constantly.
    Could it fail prematurely? Absolutely, and it likely will... probably will last several days, maybe several weeks. Hell, might be dead already, tough to tell.
    I'd let it run and go back to replace it with the right cap asap... that's just me though
    SouthEastern Virginia
    I think Skullmonkey has lockjaw.
    It might get loud!
    Nov 2001
    east kansas
    Quote Originally Posted by BSJM View Post
    No.
    The capacitor sees back EMF (Voltage) off the compressor's windings. The start and run act somewhat like a transformer.
    The back EMF will be higher than the 220vac the unit is supplied with.
    Next service call put your meter between the Herm and C and see what you get.
    Beware of advice given by some guy on the Internet.
    regina saskatchewan
    Thanks for the replies.The guy I bought the 35-370 cap from has been in the industrial electric motor rebuilding field for 30 years.He said it wouldn't be a problem.He said it may not last as long.After reading the posts here and other manuals,they all say caps can be repaced with a higher voltage rating but not lower.Also the uf can have a 10 percent difference + or - on the start cap only not the run cap.I ordered the correct cap(should be here tonite)and will replace the lower voltage one.This was an excellent lesson in capacitors for me.
    Nov 2001
    east kansas
    I only put 440 vac on my truck.
    regina saskatchewan
    Got the replacement capacitor in today.It is a 35uf with a dual voltage rating of 370/440 vac.
