Results 1 to 13 of 14
Thread: trane ch 530
    Aug 2008
    fla
    trane ch 530
    i have trane ch 530 tech view, my computer does not have a 9 pin serial port, is there anyway to hook up to this machine
    ottawa canada
    Lots of people on here will help you but without knowing your background and why you want to connect to it your not going to get help. You can do a lot of damage to the chiller if you dont know what you are doing and start playing around with settings in the various menus .
    give everyone some more info about what you want and who you are and take it from there . No offence intended .
    Apr 2008
    I used to use a usb to 9 pin adaptor on mine. Still have to have teck view to see anything.
    Aug 2008
    Pgh, Pa.
    Graham is right. First you need TechView downloaded to your computer and you need to know why you did that. Everything the basic operator needs is on the DynaView interface. If you are a tech. you best know what you are are using TechView for.
    Aug 2008
    fla
    i have work for trane for 13 year in fla, i have a comm failure on a rtac450 chiller. i have tech veiw 11.0 install but the computer that i have does have a serial port on it.
    Aug 2008
    Pgh, Pa.
    Contact Tech Support and they can tell you what cable you need to connect from a USB port.
    I reckon so.
    First off, the USB to 9pin works, but sometimes it doesn't. I have been through this with trane. You have to make sure that your usb is setup on com1 or it won't work at all. Secondly, only ch530's with newer software will work with the usb. I wish I could tell you what the earliest version in the ch530 you need for the usb will work, but I don't recall off hand. Your best bet is to find an old laptop around the shop that has a serial port and then connect. You will have fewer headaches. To load new software into the ch530 is NOT reccommended. You will have to go through the whole thing and setup it back up. This will leave you even more problems. Avoid this and find another laptop.
    If Snickers is 'totally satisfying,' then why is there a King Size?
    Aug 2008
    fla
    york chiller
    i
    Pittsburgh,PA
    what office in Florida did you work for?
    Aug 2008
    fla
    south fla trane
    Delaware
    Is South Florida Trane a commerical office or a dealership?
    Aug 2008
    fla
    commerical office
    Quote Originally Posted by dfac View Post
    Not trying to be an a$$, but if you work for a CSO why can't you get info from them or Pueblo
