Results 1 to 12 of 12
    NJ
    Javac vacuum pumps
    I am shopping for a new vacuum pump.I have a Robinair as a back up.Looking for a 1.5 to 3 cfm,lightweigth pump.
    During my search I read some good review about this pump.But it's Australian made,don't know if it's adapted for 115v,60Hz.Anybody out there owns one?
    Also I see this fjc pumps?Any opinion?
    Aug 2008
    perryville mo
    Talking i just got mine and it works great
    i tried it on 134 cooler and worked great! got mine on ebay for 79.00 and shipping 16.50 i am well pleased its 1.5 has 134 hook up and r22 also hooked up for 120 just plug and make sure u put oil in it it comes with 8 oz. for price cant beet it cj
    NJ
    Quote Originally Posted by cj2007 View Post
    which one did you got?fjc?
    Wanna, A 80.00 buck pump is an 80.00 buck pump.
    Look into J/B industries DV-42N. 1.5 CFM holds 27 oz. of oil good for up to 3 tons.
    2nd choice a J/B industries DV-85 N 3 CFM holds 27 oz. good for up to 9 tons.
    Both pumps are **** AMERICAN **** made 2 year warranty.
    I run my pumps a 1.5 a 3 and a 7 CFM for at least 12 hours minimum using a whole lot of nitrogen for sweeping in the repair of ULT units.
    Most repairs have POE in the compressors and the vacuum pump does'nt come off until I hit 75 microns.
    To date the only repair required on the 1.5 has been a shaft seal kit and ran me $ 5.00.
    Using that standard of long run times and how they get used could be a good basis in the selection of a quality back up for small system repairs.
    FEN
    Aug 2008
    perryville mo
    Thumbs up heres what i bought
    part # 6905,cfm1.5,micron rating 75,fitting size-1/4m.f.x1/2 acme,voltage115v.60 hz,motor 1/6,motor rpm 1725, oil cap. oz 6.0 wieght 14 lb it has a one year warranty from mfg.check these guys out on ebay usatoolwarehouse hope i can do this thanks cj
    Feb 2007
    Central NJ
    wannafreeze, where u work out of in jerz?
    You have to pay your due's before you pay the rent!
    NJ
    Quote Originally Posted by the mojo View Post
    I intended to buy the jb 3 ton but the weight is important.I have a heavy robinair for back up,I don't wanna carry another 30lbs around.
    I paid some $300 for my 1.2 cfm robinair,it's so beat up can't hold the oil,for the money it should have had a shut off valve and better material etc..
    100 bucks for fjc is worth throwing out if I am doing so.I will see when it arrives,how bad could it be..
    NJ
    Quote Originally Posted by wannafreeze View Post
    Unfortunately I think I did throw the 100 bucks out..
    I am about to order a JB platium..01/27/09
    NJ
    I am trying to decide whether to get 1.5 or 3 cfm...
    If your talking J/B they all weigh similar through the sizes. The smaller pumps just use more oil to fill.
