Results 1 to 6 of 6
    Malvern, Ohio
    heat recovery wheel
    Could anyone give me some info on how to clean a heat recovery wheel.
    Do I wash it, blow it out, or just replace when its dirty?
    Aug 2008
    I have washed them before with diluted evap cleaner and LOW PRESSURE water from a hose.
    Jun 2006
    midwest
    When your there cleaning condenser coils, clean the wheel, check that the brush guard is actually doing its job. I use compressed air to clean them. Water and dirt makes muddddddddddddd.
    SouthEastern Virginia
    I would consult the manufacturers suggested method for this to insure longest life. I have used low pressure water before and it worked well.
    It might get loud!
    N.E. IA
    Go to page 34. Tells you why NOT to clean wheels.
    http://semco-ms.semcoinc.com/News.nsf/0/86D57DED21A62C0786256DF200527138/$file/Wheel_Owners_Manual.pdf
    "Wheel" mechanics work on "Wheel" chillers
    Netherlands
    Most heat recovery wheels are selfcleaning. It also depends which type of wheel.
    check on klingenburg.de
