Results 1 to 7 of 7
Thread: Repacking a pump
08-13-2008, 06:30 PM #1
Repacking a pump
When installing a new packing, do you initially lubricate a sleeve, and if yes, what do you use?
I know that normally packing is lubricated and cooled by water but before gland is slowly tightened to the right tension, you need a wet suit. If you dont want to get wet during a pump startup, you start with some tension on a gland but then there is a risk of burning a packing and scoring a sleeve. This is why I am asking about lubricating a sleeve.
08-14-2008, 01:13 AM #2
- Jan 2003
- San Jose, Ca
- 2,089
I hate teflon packing. give me good old 187 I.
Never lubed packing before.Old snipes don't die they just loose their steam
08-14-2008, 08:33 AM #3
If the packing is properly installed, and you roll the shaft by hand while gently tightening, you won't need a rain suit. Individual pieces, cut so the ends perfectly butt together when installed.
I have also seen over tightening eventually break the shaft. That was from a tech who couldn't accept a drip. A properly installed stuffing box packing will drip.God Bless the USA
08-14-2008, 09:07 AM #4
Soap or Silglide.
08-14-2008, 12:44 PM #5
- Mar 2003
- 7,249
There are different procedures on different pumps, but typically no. Some pumps require a certain drip rate to cool the packing. Years ago, I installed three high temp hot water pumps that pushed 350 degree f water. They required x amount of drips per minute. They had to be adjusted with the pumps first at ambient temp, then after they reached the service temp. Had to make a shrowd to keep from getting burned.
08-14-2008, 07:09 PM #6
08-14-2008, 08:17 PM #7
Here is a link to the page instructing how to pack a pump. They say in paragraph 4 about lubricating packing rings, but they don't say with what.
http://www.dracomech.com/comppack/pumpinstall.htm
