Results 1 to 9 of 9
    Aug 2008
    Compressor winding test
    what is the proper way to tell if the windings are shorted in a compressor? I am not talking about from winding to ground. I am talking about winding to winding. Can these be checked with a megaohmmeter? I have read that the C-R and C-S winding should add up to the R-S winding resistance. Is this correct? I also know that if the ohm reading between any of the windings is zero then it is definitly shorted but what should most of the readings be?
    Mar 2001
    North Carolina
    I would tell you but it might kill you so I can't. if your a pro join the pro forums and get your answer there. can't support DIY's.
    South Carolina
    ditto
    NW burbs of Detroit
    Gee I thought I was gonna learn something new
    Aug 2008
    I am a professional hvac technicial but I understood that you have to have a certain amount of posts in order become a professional member. I am licensed in North Carolina for residential and commercial construction. This is a question that I have heard so many different responses too and I would just like to get someone elses opinion.
    Thanks.
    Clearwater, Fl
    Quote Originally Posted by rtregan View Post
    Thanks.
    Type some useless responses like this one until your post count hits 15, then apply for pro membership.
    NW burbs of Detroit
    Thanks.
    Different responses? Heh, if there is more then one way to check a comp winding resistance i am going to have to learn something new.
    Mar 2001
    North Carolina
    Thanks.
    Still this is the public forum and can not post your answer here get your post up like stated and join the pro forum then ask anything you like.
    Western NC
    Thanks.
    So are you a contractor or a HVAC tech???
    You are double labling yourself there.....
    I agree with clover....if there is another way of checking winding resistance, then its new to me...
