Results 1 to 11 of 11
Thread: 410 A check
    Aug 2008
    410 A check
    can 410 A be checked by disconecting com from compressor at contactor,
    an running condensor unit,how so. looking to se if refridgerant blend is ok
    Mar 2001
    North Carolina
    HUH
    Wow I don't get it.
    Jun 2007
    Round Rock
    What in the sam hell are you talking about? Maybe doing jumping jacks by the unit will help as well.
    Ohio
    Pull the dipstick and check that way...
    I need a new signature.....
    Mar 2001
    North Carolina
    Hows about sharing a few of them there beers
    Denver, CO
    I would just kink the little line and put one hand on each side of the kink, if one gets cold and one gets warm you got yourself a good blend
    Austin, TX
    No. There is no easy way to check the blend.
    I am for doing good to the poor, but...I think the best way of doing good to the poor, is not making them easy in poverty, but leading or driving them out of it. I observed...that the more public provisions were made for the poor, the less they provided for themselves, and of course became poorer. And, on the contrary, the less was done for them, the more they did for themselves, and became richer.
    ― Benjamin Franklin
    Warren, Michigan
    Hey guys! Why not just answer his question?
    Answer=No!
    Toddfather
    Never argue with an idiot: They'll drag you down to their level, and beat you with experience!
    The test he's talking about, would usually be done to check for mixed gasses, and or contaiminates. Works well on R22.
    If your working on a heat pump, you can do it easier then on a straight A/C. Since you have your true suction port.
    You would not pull any wires off.
    Quote Originally Posted by allan38 View Post
    Static pressure/temp relationship,will do just fine.
