Results 1 to 8 of 8
    PA/DE area
    Hybrid Heat cost program
    I have a customer that has a 92% AFUE gas heater 1 stage (the heater is stayings)and I told them to get a HEAT PUMP instead of an A/C since we get a BIG BREAK 5 cents per KW Vs 15 cents a KW from Oct 15 -May 15. I wanted someone to let her know I am not justing pushing a heat pump because it costs alittle more.thanks JC
    It's NOT the BRAND,it's the company that installs it!!!!!
    5 cents a KW?
    Dang. With a heat pump, that makes heating cheap.
    You would need NG to be 68 cents a therm, to match the heat pump at a COP of 2. Which most heat pumps are above that at any temp above 10°F.
    Sorry, I don't have a good program for the comparison.
    Jun 2007
    Bucks Co PA
    Dec 2000
    pa
    i clicked on links , but what am looking for - is the cost between fuels & the balance point of the heat pump
    Poestenkill, NY
    Work it out in excel!
    Sounds like it would be good to have a work-able spreadsheet at your finger tips with that electric rate!
    I could send you a good start - what are the rules around here regarding email addresses?
    Not in post.
    You can put it in your bio.
    Poestenkill, NY
    Not in post.
    Gotcha - thanks, I thought I read something about it somewhere ...
    Jun 2006
    Hastings, MN
    You got mail!
    Aint Notin Sweeter, Then A Brand New Heater!!!!!!!!!!
