Results 1 to 13 of 52
    May 2008
    New 15 SEER Goodman 410a system being installed. Questions...
    Right now our Air handler is in the attic. I've read its better for it to be in the closet is that true? Would our returns still be in the ceiling? Is it ok to just leave the new one in the attic?
    Should we go ahead and add insulation to the attic after we install the system.
    Our old system the repair man said was grounded? It keeps flipping the breaker. Can I see where its actually grounded at? By looking at the compressor or something?
    Houston, Texas
    In most cases your air handler would be better in the attic. That is assuming your attic is large enough for the unit and a decent service area. Some closet setups work very well, usually a closet limits the space for service, filtration and limits return air intake size.
    If your compressor is grounded, you would need a volt / ohm meter and a qualified person to see if it was grounded.
    May 2008
    What happens for it to be grounded? Is there a physical wire that has came loose? Can I open it up and see it? Can one repair it? Can one cause it?
    Sep 2001
    kalamazoo,mich
    Stop right there. Put the tools down and back away from the condenser before you get hurt.
    Have you hugged the Earth today?
    Donny Baker rules
    Quote Originally Posted by pokerhard View Post
    A wire could have come loose. Can't be repaired. You didn't cause this. You could cut the compressor open after it's removed, but why? There's an electric motor inside the compressor shell. A number of things could have caused this condition.
    May 2008
    Ok I'm just trying to understand what happened. Say you wanted to purposely ground it so it would just constantly flip the breaker if powered on. What would you do? Or how is one way it could be done?
    East of big city prices.
    I would say grounding it on purpose it`s not possible.
    Reading between the lines, either you don't trust the service company, or you want to sabotage someone. It's an electrical motor inside the metal casing. Nobody I'm aware of would purposely ground a compressor. These things happen. How old is this unit? What brand name? Model number?
    Nov 2000
    Eastern PA
    Your questions are just sounding downright dangerous
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    No, it would be an internal grounding.
    Anybody that has a GE Weathertron is on borrowed time.
    They were built like tanks. Very reliable. But, they don't last forever.
    Its over 20 years old. Let it rest in peace, with good memories.
    I missed that part. Where did it say what unit he has? Is there another thread?
    Oh, twenty year old unit and he's wondering if it's been sabotaged? Highly unlikely. I won't waste any more time here.
