Results 1 to 13 of 15
Thread: Hail!
    Hail!
    Wonder what the head is on this one?
    Oct 2006
    In a freezer or in an attic somewhere
    You could probably count the number of impact points and come up fairly accurate.
    Someone should try a comb or just place a bid.
    Jul 2000
    NW IL.
    Plus compounded by a dirty coil cause techs don't want to take the time to split them.
    Aircraft Mechanical Accessories Technician. The Air Force changed the job title to Air Craft Environmental Systems Technician. But I've decided I'll always be a Mech Acc.
    Anytown USA
    Quote Originally Posted by MechAcc View Post
    those coils dont split, they are solid.
    unless when changing the sticker from carrier to bryant they changed the coil too.
    Davie, FL
    I guess that would be why they make hail guards...
    John Culpepper's Avatar
    John Culpepper is offline CHANGE YOUR EMAIL ADDRESS Professional Member*
    Oct 2007
    Austin Texas
    Quote Originally Posted by -459FZPE View Post
    Usually the hail guard is laying on the roof next to the unit from the last time the coil was washed.
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Arizona
    Sh*t, that's a Carrier. All it takes is a hard RAIN to do that damage!
    Seriously, I hate those coils. You can't spray a hose on it that has ANY reasonable water pressure at all without folding the fins right over. They are the thinnest I've ever seen!
    True Heavy Metal Geek
    Rochester, MN
    I've lost count on how many roof top units damaged by hail!
    I don't understand by some units don't have them..
    When we were in Chicago in June, riding the El, i've seen a few Rheem/Ruud roof top units with the hail guard cut off!
    Davie, FL
    Quote Originally Posted by John Culpepper View Post
    I wonder how you tell your customer there coil is ****ed cause the lazy tech before you didn't put the hail guard back on?
    you wouldn't want to go throw away good money for hail guards would you? After spending thousands on a new unit why would you want to spend anymore to protect it?
    Davie, FL
    Quote Originally Posted by PaysonHVAC View Post
    Tell me about it. IMO there 50SX condensers are the worst, not only do they bend but if there a few years old they just fall apart.
    If your not going to be careful when cleaning some of them you might as well leave the dirt packed in them.The unit would probably be better off......
    Mid Michigan
    Talking
    Think of all the money the customer will save not having to clean the coils.
    Jun 2007
    Darby, PA
    Regular pressure from a garden hose will push fins in, let alone hail. They are the worst to clean.
    Psalm 51:10, 12
