Results 1 to 12 of 12
    ac pressure keeps fluctuating
    I had a service man at my house today due to my upstairs unit (Carrier) blowing hot. He told me that the freon pressure was constantly fluctuating. There were no leaks and it is holding its charge. He thinks that it is the pistons in the evaporator coil and they need blown out.
    Does this sound right?
    Jun 2008
    west point, ga.
    Did he look at the evap coil.
    Looked but didnt take it out. They will come tomorrow to take a more detailed look at. He stated he didnt believe the coil was damaged. Just wanted to get a "heads up" on what I will be dealing with. Dont want to get taken for a ride.
    Thanks for the reply.
    Jun 2008
    west point, ga.
    What I am wondering if it has a expanson valve(txv)
    Did you have any other work done to it in the last years.
    Quote Originally Posted by mosestr View Post
    If you don't trust them, they shouldn't be working in your home.
    sounds like to me like you might have non condensables (moisture or air) in your refrigeration circuit. Fluctuating head and suction pressures would be a sign that this is happenning. I've found that I'll see the suction pressure drop and then rise and then shortly I'll see the head pressure doing the same thing. This usually happens due to poor installation by not pulling a vaccum. My 2cents for you.
    Its not a matter of trust, but a matter of not knowing and dont want to be taken advantage of.
    Anyways...no work done to the unit other than the typical yearly check ups.
    Again they are gonna attempt to blow out the piston to make sure they are regulating the freon flow.
    Jun 2008
    west point, ga.
    Quote Originally Posted by the dangling wrangler View Post
    Yea that to.
    Beenthere also brings a good point.When was the last check up.
    Not trying to be a wise a$$ but, to me that would be trust.
    Why do you think they'll try to take advantage of you? Have they in the past?
    leland nc
    it is possible they are right
    i have seen this happen with txv and a piston,
    they should remove the piston and make sure it is clean and the seat is also clean.
    trust is hard for some people but you do have a problem in your system. The tech found it and told you about it, He also told you what he thinks needs to be done to rectify it. IMO this is showing warent for trust..
    kinda sounds like the txv is hunting?
    "The things you own end up owning you. "
    Tyler Durden
