Results 1 to 13 of 15
    Aug 2008
    Heat Pumps 1 Stage or 2 Stage?
    I had hoped that my current system would last one more summer, but it didn't. 26 years old, 4 ton, 10 SEER. 3600 SF house with 1600 of the SF in the Basement
    I am looking at replacement heat pumps.
    One is a Goodman 4 ton, 16 SEER, 9.5 HSPF, Single Stage, Heat pump
    the other is:
    Amana 4 ton, 16 SEER, 9.5 HSPF, 2-Stage, Heat pump
    is the 2-Stage worth the extra $700? everything seems to be the same except the single stage vs the 2-Stage.
    Are you replacing your furnace or air handler, too?
    Aug 2008
    Not yet and Yes
    Quote Originally Posted by badtlc View Post
    I wish I had the money to replace the furnace as well, but not in my budget right now. I have looked at them and saving for a 95% eff. 2 or 3 stage.
    For this upgrade I will be going with a new air handler. When I got my quotes, I had the contractors list the parts that would be included in the installation. For the air handler the Amana contractor suggested model MBE2000 and the Goodman contractor said model AEPF4260. I looked them up online to see specs, both models seem to be Goodman parts.
    Maybe I need to get more bids. Is getting a higher SEER worth the huge increase in price? 18 SEER? 21 SEER?
    Won't get much of a savings by going 18 or 21 SEER compared to a 16 SEER. A couple bucks only.
    Aug 2008
    Connecticut
    Quote Originally Posted by AlabamaDave View Post
    The reason you see that is because amana wanted to buy the company goodman out, but instead Goodman turned around and pruchased amana, so any new amana you see out there is really a goodman at heart now.
    thats why those models are referencing like that
    Aug 2008
    Ok I'm convinced
    I'll go with the 2-Stage compressor and a VS air handler.
    not 100% sold on the Amana, if it in fact the same company as Goodman. I wanted quotes from different companies, to get the best product at the best price.
    I wish that I could ask good prices here for a complete replacement system and installation rates, but since I can not. I will let my fingers do the walking in the yellow pages with the knowledge that I learned here and see the cost proposals.
    Any companies that I should stay away from?
    Thanks again for the help,
    Dave
    DC Metro Area (MD)
    The Amana products that start with A are genuine Amana products, not rebadged Goodmans. Different product. The Goodman SSZ16 is only a 2-stage unit in the 5-ton size.
    The Amana 2 stage HP, is not a Goodman product.
    Goodman doesn't have a 2 stage 4 ton unit in split systems.
    They are not the same product.
    But you can always get a price on a York Affinity 15 SEER 2 stage heat pump.
    They have an 18 SEER also, but you won't save enough in 20 years to pay for it.
    Aug 2008
    Connecticut
    only advice is make sure that whoever installs it properly stages your heating and cooling. especially for your heat pump end, they should be installing outdoor tstats so your stages run at specific outdoor ambient air temperatures for proper system eff.
    Jul 2001
    Gold Coast of Connecticut
    the other is:
    Yes is is worth it...........great upgrade !
    Aire Serv of SW Connecticut- Gas heat, dual fuel and central a/c systems installed and serviced
    Besides being 2 stage, the Amana unit is a nicer product. Sound deadening top, 2 speed fan motor, Copeland's Comfort Alert control/diagnostics module. But the Goodman ain't too shabby with Copeland scroll under cover, high & low pressure protection.
    Besides the increase in $$$ for the 2-stage heat pump, you will probably also need to spend more $$$ for a variable speed air handler or furnace to go with that 2-stage heat pump. That would be another thing to consider.
    DC Metro Area (MD)
    I agree with the Amana option if you're going with a v/s furnace or air handler too. You'll find that without one the efficiency drops too.
