Page 3 of 5 FirstFirst 12345 LastLast
Results 27 to 39 of 61
  1. #27
    OK guys, I don't want no trouble here. I'm just trying find out what I current have so I won't get something that's oversized.
  2. #28
    Quote Originally Posted by 3DD View Post
    Well, we're figuring that out right now. It's going to be between 1 1/2 & 5 tons. Close enough? Oh, I hope you don't think this is a heated debate. It isn't. Not even close.
  3. #29
    Quote Originally Posted by the dangling wrangler View Post
    ROFL.
    This isn't even close to a warm debate on this site.
  4. #30
    Ok.
    So why not measure up the house, and do a load calc on it, to make sure you put the right size in.
  5. #31
    Ok.
    This is actually funny. I've gotten 4 A/C guys, and none of them offered to do a load calculation.
  6. #32
    OK. Let's see if I could get a model number off the compressor, and we can turn up the heat a bit more. Could it be a 3 or 4. The time it takes to cool (or almost cool) the house, it ain't a 5...
  7. #33
    And did they give any idea of the size?
    So far you told us nothing about your house either.
    Weatehr the old one kept up or not. Did it cycle on and off, at design temp.
    Was your house damp that you had to set your stat lower to get the humidity out.
    If you want, you can do your own load calc.
    http://hvaccomputer.com/talkref.asp
    And find out what size you need.
  8. #34
  9. #35
    I've run across some units that the nomenclature tag was sun washed & the compressors were so rusted over you couldn't even read it .But, you might get lucky and only have to look and, there it is. Your service contractors should know what alternatives to take to get this information. They should be embarrassed if you have to tell them how to find this. It's not all that hard. Time consuming, yes.
  10. #36
    Oh yeah. The house is about 1700, with a room above the garage, and this room pretty much gets the sun all day. The A/C takes about 3+ hrs to cool the house from 85 to 80 on 95 degrees days, which I think is too long, and on the 95+ days, the A/C can't seem to the temp low enough so it's always on.
  11. #37
    And 3 A/C guys say 4 tons, and 1 recommends a 5.
  12. #38
    I got this off the compressor, and I really appreciate your help trying to decode this for me:
    AH301 FT-077
    E L 2 6c 995131 AH5?46E
    V200 Hx50 PH1
  13. #39
    Between the AH and 5, there should be another letter.
    Between the 5 and the 4, it was probably another 5.
    But that should be a 46,000 BTU R22 air conditioning compressor.
