Page 2 of 5 FirstFirst 12345 LastLast
Results 14 to 26 of 61
    LOL...
    Dang, I was trying to get something for nothing.
    It was a good question. I guess the next step would be to measure the blower diameter, motor hp, and furnace/A-H rating, maybe take a look at the run cap rating. What would beenthere do in this predicament?
    Arizona
    I was thinking that would make it a 13 SEER?
    I'd measure. But not any of the things you said.
    Quote Originally Posted by jimj View Post
    And, what tonnage would that 13 be??
    None? Been, I really don't care how or what you'd do here, so don't tell me. Deal?
    Quote Originally Posted by the dangling wrangler View Post
    None?
    Nope.
    Its probably old enough, its time for a new unit. I'd go into salesman mode.
    Which means I'd be measuring up the house, for a new system.
    If I can't read the model number and blower rating of the furnace. Its time for a new furnace too.
    Ok, Some people won't spring for a new furnace at the same time.
    But I have never seen a furnace with a 2 ton blower. Minimum around here is 3 tons.
    So I'd be safe that it has a 3 ton drive.
    I might measure the blower, if I didn't reconize the brand.
    ya got me.
    Nope
    I knew that was coming.
    You edited your post while I was typing.
    Houston,Tx.
    Quote Originally Posted by 3DD View Post
    Hi Guys,
    Is it possible to find out the tonnage of the AC from the compressor?
    I carry a scale if it's a two ton it should weigh close to four thousand pounds I believe.
    It was an after thought. But, I think we both would have came to the same conclusion. I do things my way, you do things your way. Dosen't mean either is better.
    I don't know
    I have seen two in my lifetime and I'm not even in the field.
    They exist (a lot of older furnaces have small blowers), so don't assume that it's 3 ton drive.
    It must have to do with climate; where I am, heating is a necesessity, a/c is just a luxury which doesn't get used much.
    I've discovered a natural law - everything gets progressively worse. Things only break down and become depleted. Life isn't worth living and everything is going to hell.
    Death is the messiah. Everything else is irrelevant and arbitrary.
    I was more hoping the OP, would get the idea to just size up the house, and give his customer options.
    For both repair and replacement.
    Quote Originally Posted by amd View Post
    There's a number of them here. The first that come to mind, is the replacement unit for the old G&S stack-pack units.
