Results 1 to 10 of 10
    Aug 2008
    St Petersburg, FL
    10SEER w/ 13SEER
    What are the disadvantages to a system with a 13 SEER condensing unit and a 10 SEER air handler.
    Jul 2002
    Zelienople, Pa
    Lower efficiency and capacity.
    Also some manufacturer's will void a warranty on a mis-matched frankenstein system.
    Do it right, or don't do it at all.
    Aug 2008
    St Petersburg, FL
    need a bucket JARHEAD??
    Gov funds tie me up
    Jul 2002
    Zelienople, Pa
    Quote Originally Posted by BACH View Post
    Gov funds tie me up
    You are asking the disadvantages, how about I list all of the advantages:
    1. NONE!
    Aug 2008
    St Petersburg, FL
    thanks
    Loss of capacity.
    uses more electric then a matched 13 SEER system.
    Some manufacturers void compressor warranty.(They require the indoor coil model and serieal number to get compressor warranty)
    Here's a report.
    SW Wisconsin
    It is NOT a 10-seer air handler, it is a 10-seer evaporator coil.
    Air handlers have nothing to do with the mismatch we are discussing.
    Were I not retired & there, & you absolutely could not afford a 13-seer matched coil, I would have reconditioned a 10-seer condenser for you.
    Have you already replaced the condensing unit?
    Why are you replacing the 10-seer condenser?
    What was the diagnosis data told to you or left on the invoice?
    Another report,if the first one didn't convince someone.
    Aug 2008
    St Petersburg, FL
    compressor locked up
    Post model #s in & out
