Results 1 to 9 of 9
    Aug 2008
    Please help explain
    Hi there, I have come to this forum looking for help figuring out what to do about my AC unit, and to be sure that I have exhausted all options. I am disabled on a low income, and am freaking out. I was out of town and my neighbor walking my dog called to tell me my AC wasn't working and it was boiling in the house.
    Long story short, the AC company came and checked it out. They left me an invoice that said "unit is locked pulling 120 amps, tried new hardstart did not help, old hard start had come apart due to high amperage draw. Needs new compressor."
    This is a 7 year old Rheem unit, don't know the size but when it was new it was high efficiency.
    I have a couple of questions, the first being about what that even means as far as pulling those amps. And why I had a hard start put in not even a year ago that had come apart? At the time the tech said it was optional, but would extend the life of the unit considerably. Well it has been 11 months.
    Next, I want to be sure I shouldn't call an electrician first. Everything was fine, and 2 weeks ago my neighbor came and installed a digital thermostat since the old one wasn't digital and he said I would save money. Immediately, the AC stopped working. He came out the next day and said one of the wires, that went from the thermostat to the compressor, had popped out. He put it back in, but said the wire was very thin. He came out yesterday and checked to see if that was the problem but he said the wire was in there, but I wonder if it is a problem with the thin-ness of the wire, or could somehow be related to the thermostat? It seems like a strange coincidence that the compressor appears to have been blown out by high amps.
    He is not an electrician.
    I have a call in to the tech who came out here since yesterday, but so far I haven't heard anything.
    But let's just say hypothetically that that same wire broke behind the wall. Would the AC tech be able to tell that when he checked the compressor? Or would he just assume the compressor was broken since he tried everything and couldn't get it to start?
    Anyone know how much the range is for something like this, if I do need a new compressor, in the Atlanta area?
    Thanks for any help you can provide, I just don't know what to do. And it is 9 am and already 86 degrees in here.
    The thermostat wire doesn't effect the amp draw of the compressor.
    It only controls a contactor.
    The locked rotor amp draw means the compressor is seized.
    It was probably showing troubles when the tech was there last year, and that is why he recomended the hard start kit. To try and get you longer life from the compressor.
    You might want to se if your local Community Action Program can help you.
    As far as cost, we don't talk about prices here. As it varies from one area to the next.
    And it is against the rules.
    Aug 2008
    Thanks!
    Hi, thanks for the info. Sorry to break the rules, I am so stinkin hot I guess I didn't take the time to read them and should have!
    Glad to know that it's probably not related to the thermostat, just a coincidence I guess.
    Sure wish there was a possibility of doing something else as a band-aid until I can figure out how to pay for a compressor.
    NW AR
    Quote Originally Posted by piglet66 View Post
    Whats the model and serial for the outside unit. Most the Rheem I install come with a 10 yr. comp. warranty.
    Aug 2008
    Model
    Well on the unit it says it is a Rheem Classic 10 SEER "Scroll Inside." Don't know how many tons, but it is for approx 1800 sq. ft. Knowing this builder, it's probably the minimum adequate size for this house. It never gets freezing cold in here, it works very hard.
    The AC guy wrote this info down on the service ticket:
    Model RAKA-048JAZ
    Serial 5432 M4400 06954
    This house was bought new less than 8 years ago.
    Thanks!
    4 tons for 1800 sq ft. Thats a lot for most that size house in most areas.
    Aug 2008
    Well I am glad to hear it is the right size. I keep seeing info to lead me to believe it is a 10 year warranty, but for some reason the distributor is telling my AC people it is only 5 years.
    Houston,Tx.
    Model RAKA-048JAZ
    Thanks!
    The RAKA has a 5 year compressor warranty and that is a fact.
    NW AR
    Yes, 5 yrs. Would be oversized even where I live and its a hot, humid, mofo here.
