Page 4 of 4 FirstFirst 1234
Results 40 to 43 of 43
  1. #40
    State College, PA
    Solution:
    Do not service accounts without maintenance contract.
    Or:
    You get to replace more compressors.
    Can someone please explain to me -
    Why is there never enough time to do it right the first time, but plenty of time to do it twice?
    Please view site rules: http://hvac-talk.com/vbb/showthread.php?t=1241
    Apply for Pro Membership: http://hvac-talk.com/vbb/showthread.php?t=116113
    Find your local HVAC-Talk Contractor: http://hvac-talk.com/aop
  2. #41
    Sep 2003
    North-Central Ohio
    Quote Originally Posted by letsmakesense View Post
    It is my understanding (field rep. united refrigeration) that the residue is a sodium based chemical solidified from a high heat condition.It collects in the condenser and there is no known remedy. I too am plagued with this affliction.
    barry
    I believe letsmakesense is right. I had a "compressor rep" tell me the same thing when discussing the issues we have seen with small POE/ cap tube systems. We are at the point that we steer clear or recommend replacing the entire unit when we see a plugged cap simply because the original cause of the oil breakdown (dirty condenser coil/ bad fan) has surely damaged the compressor and then add on top of that a plugged cap - bad news. When describing the problem to our customers I use the analogy of hardening of the arteries (plugged cap) which then leads to heart failure (compressor).
    If a customer really wants to go down the repair road, bare minimum is a new compressor, cap, AND replace the worthless spun copper drier for a larger filter/dryer.
  3. #42
    Jan 2011
    Quote Originally Posted by ammoniadog View Post
    That almost sounds like a good idea, but wouldn't that just make the condenser get dirtier, and in turn make the cap tube plug up again sooner?
    I am thinking of a typical customer here that does no maintenance and only calls when it quits working. For someone who gets regular maintenance, it sounds like a good plan.
    I had nothing to loose when I tried this. Customer was turning off the ac at night and could smoke a compressor in 30 days. They have not lost one compressor since and still do not run the air at night. Yes the coils get dirty faster.
  4. #43
    Apr 2003
    Maple Grove, MN
    Quote Originally Posted by cool_tech_llc View Post
    Be careful when changing to a larger filter drier. If the drier is too big, the liquid will flash away and then you will be trying to push gas through your cap-tube. It won't work right. I agree with getting rid of the spun copper thing and going with a real filter-drier, but use a tiny one instead of a big one.
