    Aug 2008
    Question New HVAC unit or not
    I have a 11 year old Bryant Heat pump 12 seer package unit with 15 kw heat strips . (3.50 ton ) Very well insulated house last months electric bill was $132.00 . T-stat set between 76-78 at most times cooling and 68-69 heating . Winter bill usaully gets to $145.00
    I am not having any problems yet but most everyone is telling me the average life on a heat pump is 13 years . I have not had one problem with my Bryant unit so I started looking at them again .
    Questions :
    Do you replace before they start breaking down ? Is 13 years really true ?
    Units I am looking at :
    Trane 16 seer package 9.0 (most expensive)
    Bryant 15 Seer Package 8.0
    American Standard 15 seer (haven't priced yet )
    How much money can I save by going to one of these units ?
    Others things to consider is my unit now is LOUD ! What unit will give me as good reliablity ? Trane higher seer rating but very good luck with Bryant so far .
    How do I get the ARI ratings on these units ?
    Thank you
    Don
    SW Wisconsin
    A 12-SEER Unit with components added can YIELD 13-SEER Performance
    Concerning equipment component life, a lot depends on the quality of he initial installation & set-up. Your unit system could last 20 years.
    Right sizing of the system & selection of longer cycle room T-stats help reduce the number of starts, which is hard on equipment components.
    There is no way to predict whether a new unit will have some early component failures. It is cost-effective to replace low cost component failures.
    Good maintenance practices, keeping filters changed & condenser & evap-coils clean, help reduce major component failures.
    With RIGHT SIZING & proper cycle controlling ROOM T-stat & other components a TXV,etc., a 12-SEER unit can USUALLY YIELD 13-SEER performance. They should have been allowed to mfg'er them & the 10-SEER units, there are climates where they work very well.
    Everyone can't afford the new higher SEER Rated equipment.
    Got work to do... - Darrell
    Aug 2008
    Question New or not ?
    I do keep my filter changed and my coils cleaned . Can you still tell me where to get the ARI ratings on these units .
    Thank You
    Don
