Results 1 to 9 of 9
    Columbus
    Question Condenser runs and stops
    I installed a new condenser a few months ago June 08. York 13 seer 1.5 ton. At first pressure was irregular on highside 350-375 psi. Balanced highside pressure to 225-250psi. Then lowside pressure shot up to 80psi. Balanced lowside psi to 70 psi. Unit runs ok for 10 minutes good sweat on lowside pressures are ok,then shuts off. Although highside doesn't get warm, in fact it didn't get warm at all. When I balancing the pressure there was a lot of refrigerant oil recovered(milky white). Is this unit oil logged?
    Western NC
    HUH??????
    Alabama
    Dude, when a unit shuts off that means the stat satisfied......most of the time......
    you got milky problems for sure!!!
    Western NC
    Quote Originally Posted by superd77 View Post
    I think the milk is cloudin up the brain
    Alabama
    Quote Originally Posted by iraqveteran View Post
    Yep!!!!!
    Nov 2000
    Eastern PA
    This is a double posted thread. The original thread is here; http://www.hvac-talk.com/vbb/showthread.php?t=178593
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
    Western NC
    Quote Originally Posted by RoBoTeq View Post
    I reject your reality and substitute my own
    This is the one and only original.
    UUHHHH ooooohhhh the DIY'er doesn't know that moisture is a very very bad thing
    bey the DIY'er doesn't know how to fix it either
    time for somebody to call a professional
    Aug 2008
    Moisture-condensibles
    When you installed the unit did you vaccum system down? Did you use a micron gauge? How low did you vaccum the system down too? Does the system have a filter dryer?
    Sounds like moisture problem!
    Good Luck
