Results 1 to 8 of 8
    Jackson, NJ
    Question Cycle Time Adjustment ?
    Hey Gang,
    Can the cycle time be adjusted at the blower/heatpump/furnace and not just at the stat?
    My HVAC guy came by and spent awhile downstairs. He said he increased the cycle time but didn't go into detail as to how (and I couldn't ask as my boss was sitting across from me when he called in to say he left the house). I asked if he changed the CPM at the stat and he said 'No, I took care of the timing at the unit'.
    Any idea what he could've done? He was already by once to slow the fan speed (didnt work). Maybe he could've lowered it some more? I don't know. It hasn't been that hot here so I can't see if anything is better /worse yet.
    A Lan Far, Far Away in Podunk, Georgia
    This is an outrageous answer but.... when I want my heat pump to run longer, I simply lower or raise the thermostat setting a few degrees past where I actually want it. It just sets there and runs until that'ol thermostat is satisfied.
    That seems to magically make it do what I want.
    Sorry if I didn't understand your question.
    burlington county n.j.
    only thing that can be adjusted at the furnace may be the fan off delay or the blower speed. cycle rate is the job of the thermostat.
    Jackson, NJ
    Well, whatever he did now its really screwed up. The stat calls for cool and the compressor doesn't kick on for over 10 minutes.
    Maybe he installed a delay relay, to hold off the compressor only.
    So that you think the A/C is running longer.
    Jackson, NJ
    That's what I was thinking, though I didn't know the technical particulars. But now the system calls for Cold, waits anywhere from 10-40 minutes, then fires off the compressor. Its all botched up now. My HVAC guy thinks something happened to the board outside on the Heat Pump, but wants to come back to diagnose.
    What a pain this is becoming.
    He DID tell me that it is normal for the system to call for cold, and have the fan run for 5 minutes or so before the compressor fires up. He said there is a delay from when the system 'energizes' to when the compressor will actually turn on. I've never experienced a system like that before, but he is fairly adamament that this is normal behavior for this Ruud.
    The stat and defrost board both have 5 minute anti short cycle timers bult into them.
    But they only prevent you from restarting your system quicker then 5 minutes.
    If your system has been off for 10 minutes and you adjust your stat to call, they should come on right away.
    After all, a 40 minute delay,would allow the temp to rise fairly high when the OD temp was near design.
    Jackson, NJ
    That's what I thought too. And that's the way the system was behaving before whatever went south. Hopefully its as simple as replacing the outside board.
