Results 1 to 8 of 8
Thread: UV lights
08-02-2008, 01:53 AM #1
- Jun 2008
- central east, WI
- 8
UV lights
I am curious what other HVAC professionals think about UV lights? I have had customers tell me how less sick they are, and how happy they are with there UV light. Some have told me that there alergies have almost gone away since there UV light was installed. I am debating if I should put one in my house. I also wonder if they are effective at killing mold and yeast spores. I my self think the return is the best place to install a UV light, yet there is arguments for both supply or return installation. Let me know what you think.
08-02-2008, 08:51 AM #2
Banned
- Aug 2002
- Office and warehouse in both Crystal River & New Port Richey ,FL
- 18,836
The air travels too fast for UV to affect the particles in the air.
It can kill mold,etc.,on the indoor coil,best to be on the supply side,if possible.However some cheaper versions won't wrk well in the cold air,check their specs.,if they have none,keep looking.
They will actually clean an impacted coil,impressive.Best to leave them on 24/7 ,replace once a year.
08-02-2008, 09:05 AM #3
- Jul 2008
- 53
Check me if I'm wrong, but any plastic exposed to a UV light would break down faster, correct?
I'm thinking of the drain pans in most systems, as well as the inner liner of flex duct, wiring etc.
08-02-2008, 09:35 AM #4
Banned
- Aug 2002
- 18,836
08-04-2008, 12:59 AM #5
- Mar 2005
- reading PA
- 20
uv lights
whats the deal with 24v uv lights? how do they compare withe 120v ones?
08-04-2008, 05:25 PM #6
- Jun 2008
- central east, WI
- 8
I din't even know they made 24v UV lights. My first thought is not enough power to kill much. However, I am not shure. I am still debating if I should put a 110v UV light in and wich brand to go with?
08-04-2008, 09:26 PM #7
Banned
- Aug 2002
- 18,836
08-05-2008, 06:55 AM #8
Good IAQ requires a minimum of 50 cfm of fresh air when the people are in the home, a good filter to keep the air handling system clean, <50%RH during the spring/summer/fall, and elimination of all continuous wet spots. The rest of these ideas are minor by comparison of the above. EPA American Lung ass etc stating this in writing. Get every gadget you can right the above. Regards TB
