    Aug 2008
    SW, Va
    Old Heat pump runs constantly on "heat"..
    Hi all, first post. I live in an apartment that uses an old, early 80's Lennox 2-stage heat pump. When using this in the winter, it NEVER shuts off. It will reach the desired temp,(the green indicator on the t-stat goes off)but it continues to run. I have to manually cut it off. Looks like the t-stat was changed to a newer unit(still with mercury switches though)
    Any ideas? The electric bill is getting insane.
    Thanks, Vinny
    Apr 2008
    TEXAS
    Confused
    apparently you have heat pump that is almost 30 years old. if i were to guess, that would also be your problem. without a thorough going over its impossible to tell. it could be sticky contacts or faulty t stat. does the cooling side work ok?
    "When the people find they can vote themselves money,that will herald the end of the republic" - Benjamin Franklin
    "Government is not reason, it is not eloquence, it is force;like fire, a troublesome servant and a fearful master. Never for a moment should it be left to irresponsible action"- George Washington
    Aug 2008
    SW, Va
    Cooling works okay. It is just the heat side that will not shut off.
