    Aug 2008
    Pipe nipples on Evaporator box...
    I searched before posting, and could not find an answer to this (hopefully) easy question.
    I have a central air unit which is running well. It was put in about 12 years ago. It has evaporator / natural gas furnace in the attic and the condenser/compressor outside (don't have actual models at the moment, but may not be necessary with the generic question)
    Was inspecting the duct in the attic and it all looked fine
    While checking air handler, noticed two metal pipe nipples (1/2" it looked like) directly above one another and about 12 inches above the normal drain port and refrigerant piping penetrations.
    Thing is, they were open and blowing quite a bit of cold air out. Are these suppose to be capped or would they be used for some other reason? It seems funny that they would be wide open blowing cold air out straight out of the box.
    Any help would be appreciated.
    Thanks,
    Tim
    North Dallas
    Sounds like a multi position coil and those would of been the drain ports if installed vertical instead of horizontal. Maybe installer didn't have caps back in the day.
    Aug 2008
    Thank you tdlaskaris, that makes sense. I will put a cap on them ASAP, unless anyone else recommends otherwise.
    Feb 2005
    In a van by the river
    I agree with TD, atleast that's what it sounds like... Good luck with that.
    ## + years in the field never made you a know-it-all This industry is far more diverse than you are
    burlington county n.j.
    agree with the others, probably 3/4" pipe thread.
