Results 1 to 13 of 17
    Can a rube like me clean the evaporator coils?
    I have a Carrier FA4BNF048 that keeps icing up. I'm guessing (and please tell me if I'm off base) that this may be the result of something that happened a while ago:
    I neglected to change the blue fiberglass filter (don't worry, I've switched to pleated paper since). The unit iced solid and when it thawed, it drenched the filter which disintegrated and got sucked up into the evaporator.
    I took a grate of one of the returns and snaked the hose from my shop vac underneath, but then had to reach in though the little slot for the air filter to actually do the cleaning.
    Is this something your layman should be able to do, or do I have to call in a professional?
    The Gray Northwest
    If your coil is icing up, better get it checked out and soon.
    Doubt if you're gonna get much guidance on here
    young grasshopper.
    No pricing, no DIY, please read Site Rules Register
    Lincoln, Nebraska
    If your using one of those 3m pleated filters that may be your whole problem. They restrict air even when clean.
    Its a good Life!
    I'll call a pro, but I'll have to clean my garage first!
    san antonio
    Confused 3m filters bad?
    Never heard that 3m filters restrict air flow right off the bat, true?
    Jul 2002
    Zelienople, Pa
    Quote Originally Posted by sanantoniotech View Post
    true
    110% TRUE!!!
    many standard air handlers cannot handle the pressure drop across the pleated type filters, even with fan on high speed. They may be okay for the first week or so, but when filters start to get loaded airlfow drops off and presto. We have one building where the owner is willing to change filters monthly to keep the place clean by using pleated filters. Every unit is less than two years old, and is a standard carrier. If left for more than one month, I get calls about units freezing up. He is not willing to go to regular filters.
    Removed 2 today at seperate jobs.
    The 3M pleated filters are fine, if you're ductwork is designed for that level of drop. Which most aren't. I tell all customers not to use them, but if they insist, I tell them to change them weekly, or I'll be back soon, to tell them why the system has iced up. Again. 3M's are not good.
    memphis
    pleated filters
    I tell a lot of my customers to go to the cheaper filters to improve ac performance. Some units just can't push through the thicker stuff!!!
    Jun 2008
    west point, ga.
    Tell them to use fiberglass filters and sprinkle furniture polish on them.
