Page 4 of 9 FirstFirst 123456789 LastLast
Results 40 to 52 of 114
  1. #40
    Actually our distributor, rarely has anything with the goodman badge on it, It is either Amana, or "Distinctions" by amana for the goodman stuff, same model #'s and everything as the goodman label.
  2. #41
    Cedar Grove, Wi-Sheboygan
    I would venture to say that the "Brand Bashers" would change their opinion on Goodman if us regular HO's were not able to purchase the Goodman equipment off the net or other places and not be able to do self installs
  3. #42
    Mar 2006
    Hey! no DIY here. I only went on about sound proofing.
  4. #43
    Jul 2002
    Zelienople, Pa
    Quote Originally Posted by DanW13 View Post
    If you could have the best install team and company to install a system and money wasn't in the equation, would all of you still choose Goodman?
    It isn't bad equipment if its installed correctly, but there are some areas it just doesn't excel in when comparing it to other brands.
  5. #44
    Des Plaines,IL
    Quote Originally Posted by Swampfox View Post
    To anyone who actually works in the field on these things and likes them....
    Next time you have the chance, completely remove the top of one of the newer style outdoor units, condenser fan wires and all, then reinstall it, you will have a new opinion of Goodman
    I pm'ed a 13 SEER GSC condensing unit, and although it was a little difficult to get back together, it was much easier to clean the condenser coil than the older units. As far as disconnecting and reconnecting the fan wires it was just as equally difficult as with the older condenser units.
    Stuart
    Lack of airflow destroys compressors.
  6. #45
    Quote Originally Posted by Gunnery Sergeant Hartman View Post
    If it was a 5 ton that I needed, I might.
    Goodman doesn't have 2 stage A/C in units smaller then 5 ton.
  7. #46
    Richmond, Virginia
    Builder Grade 1999 Goodman
    I think you may have opened another can of worms, mallard. This thread has the name "Goodman" in it.
    I don't see a huge difference between Goodman/Amana products and other brands. Of course Trane has the spine-fin coil, which people either love or hate. Parts wise, they are all pretty similar. Some have more features than others. Amana is not a bad product in my opinion. Any brand can break. Installation is key. I'm sure I've pretty much repeated what everyone else has already said, but so be it.
    It came with the house so I didn't have a choice; appeared to the novice (me) that it was installed properly...performed very well for 9 years, then a leak in outside coil was cause for new system...just like Ryan said, parts fail and a homeowner out of warranty must do a cost/benefit analysis to ascertain the value of a parts replacement or a new system ...I opted for a new system ..AS with a 10 year extended warranty ....that being said, it does appear from my cursory research (post new installation) that a 1999 installed Goodman is not even close to what I perceive as a vastly improved 2008 Goodman...for this homeowner, a reliable install and an extended warranty is much more important than a particular brand
  8. #47
    Feb 2007
    Las Vegas,NV
    The 2008 catalog I have shows a two stage comp on the 15 seer package unit in 3,4 and 5 tons.
    Maybe something they just changed.
  9. #48
    DC Metro Area (MD)
    Quote Originally Posted by sammy37 View Post
    Think he's talking about the SSX16/SSZ16.
  10. #49
    I was thinking of the split systems.
    Amana has it, Goodman doesn't, or didn't.
  11. #50
    Hell Hole Swamp
    Look around, you can buy pretty much any make/model on the internet, no manufacturer condones internet sales direct to homeowners, it is distributors/contractors that are doing this.
  12. #51
    Jun 2008
    Cincinnati, Ohio
    THANK YOU!!! I was hoping someone would bring this point up.
  13. #52
    Hell Hole Swamp
    Quote Originally Posted by mcewans View Post
    try it on a GSH then, the distributor and outlet header are right in front of the hole where the wires go, on the one I did it was damn near impossible to get the wires back in and hold the top up by yourself, they also zip tie the wires to the coil, very stupid design IMO
