Thread: Second System
    Second System
    I moved into a 2000 sq (excluding unfinished basement) ft 77 year old home. The home is three levels with one of them being an unfinished basement. The back room on the lower level is an addition of one bedroom and one bathroom. Upstairs is two more bedrooms and one bathroom. When we purchased the house the previous owners failed to mention a problem with the a/c. Lets just say the second floor stays around 78 degrees even with the a/c system on all day.
    The system is a Heil 2.5 ton with a gas furnace also.
    My plan was to install (have installed) a new system for the upstairs two bedrooms.
    I have gotten numerous quotes and the one I decided on is
    2.0 ton american standard
    2.5 ton airhandler
    10 kw heat strip
    ductwork in attic into existing ductwork and new ducts to each bedroom
    return in ceiling
    blocking flow from original unit upstairs, ect.
    I am also having to get a lot of electrical done (my panel is full, and it is split bus). I am bringing it up to code with a new 200 amp panel, line for condenser and lines for attic.
    The first number job includes doing some repairs to old system including adding insulated flex duct to the addition on the 1st floor and replacing the line set on the old unit (faulty install).
    Am I doing the right thing?
    All comments welcome. Thanks
    Second System,replacing ,or adding another system??
    second system
    I am adding the second system and keeping the first. So will have 2.5 (basement and downstairs) + 2.0 (upstairs).
    Did they do a load calculation to determine the size need?
    Is the downstairs larger then the upstairs,basement completly underground or partially??
    second system
    they did do a load calc and came up with approx 4 tons needed. it was going to be cheaper to install the second system than replace the one existing. Also the ductwork to the second floor would need to be redone with a totally new system.
    The basement is partially underground. Stays pretty cool.
    And yes the downstairs livable portion is larger than the two bedrooms upstairs.
