    TrueSteam VisionPro IAQ - stops on call for A/C
    I installed a TrueSteam humidifier with a VisionPro IAQ thermo/humidistat. The humidistat function on the IAQ unit successfully runs the humidfier until a call is made for cooling. Then the Truesteam unit shuts down and the system runs A/C. Afterwards, humidity drops and the system is not turning the Truesteam unit on. The only way I can get it to run is to re-program system option 374 on the EIM. Then, provided the EIM initializes without a call for cooling the Truesteam will function.
    Two problems:
    First, I bought the Truesteam specifically to run simultaneously with A/C. RH is often around 25% and with A/C it can drop below 20%. Besides dry skin and respiratory health concerns, we get painful ESD around here. Unfortunately, I can't seem to confirm from documentation that the TrueSteam/IAQ will actually run cooling and humidification simultaneously. I just assumed it would because it's steam.
    Second, calls for A/C not only shut off the TrueSteam, they seem to disable it until I reprogram the EIM.
    I have wired the system according to both the "independent" and "dependent" schemes in the installation guide. I am not using an AFS. I have tried various combinations of wiring, dip switch settings, and system option (370, 372, 374) configurations as indicated in the documentation.
    I get successful humidity and fan calls in both dependent and independent modes. But as soon as a cooling call is made, the Truesteam is down.
    Advice?
    Ok so I'm starting to understand I'm going to need ANOTHER humidistat?
    British Columbia, Canada
    Quote Originally Posted by BenjaminM View Post
    Two problems:
    Advice?
    I would first speed the evaporator fan up a speed if possible to do less dehumidification. To my knowledge you will probably have to have a seperate control if you want the humidifier to run with the A/C unit.
    Not that I did not tell you anything you probably did not already know. J
