Thread: ERV simplified vs dedicated
07-27-2008, 10:23 PM #1
New Guest
- Jul 2008
- 2
I bought a new house, and it will be built this year. I am given an option as an upgrade to have a dedicated duct system installed for an ERV/HRV. I do not plan on getting the ERV/HRV from the builder, but from a local HVAC company. Would you recommend getting the dedicated system or just let them use the simplified installation?
Thanks,
Kevin
07-28-2008, 12:44 AM #2
Professional Member*
- Jul 2000
- Northern Wisconsin
- 1,566
Depends on how you plan on running your HVAC system. If you plan on running your blower continuously then a simplified version of an install (connected into the ductwork of the primary system) will do an adequate job.
07-29-2008, 04:43 PM #3
What climate do you live in? Regards TB
07-31-2008, 12:45 AM #4
New Guest
- Jul 2008
- 2
