Results 1 to 13 of 26
    North Dallas
    What do you think?
    American Standard condensing unit trips thermals. Was able to briefly check before tripping again...takes forever to reset. Coils, fans, capacitors were good. Head pressure operating at 340 psi with 70 psi suction, not enough time to measure SC or SH, @ 90 degrees ambient. Discharge line extremely hot(out of compressor,into cond) and not even warm leaving condenser (almost cool even). Compressor drawing 22.3 amps (Rated Load Amps 18.6). While off on thermals and cond fan still operating refer pressures never equalized, as a matter of fact 10 min into it static pressures were 290/ 136 psi.
    Lincoln, Nebraska
    Are you a pro. If so the answer should be right in front of you. Get your post count up and apply for pro membership.
    If a homeowner we can offer no DIY help and you need to get the unit serviced.
    Its a good Life!
    Im not sure he is a pro, especially if he was expecting the discharge line not to be very hot, and yes the answer is in front of him.
    North Dallas
    Restricted condenser coil. With what...oil or non condensables with air robbing space in the coil? Ofcourse the dicharge line is gonna be hot sh.t head but obviously its alot higher than norm!
    Quote Originally Posted by tdlaskaris View Post
    Restricted condenser coil. With what...oil?
    Call a technician before you do further damage.
    North Dallas
    If you have nothing better to offer or say than don't. Throw your two sense in and lets see who is the pro!
    WHY DONT YOU READ THE SITE RULES , NO DIY . You obviously do not know what you are doing, so call someone who does. You are not going to get your answer here.
    DC Metro area
    If you are a pro there are professional forums here where you can get help with technical issues such as the one you're describing. You have to apply for "pro membership."
    North Dallas
    Yes I am a DIYer that is gonna recover refrigerant, pull a vacuum, and charge a system... you dumb bastar.
    DC Metro area
    Here are the site rules you agreed to when you signed up: http://hvac-talk.com/vbb/showthread.php?threadid=1241
    I shouldn't be playing mod. I'm done...
    North Dallas
    HVAC-Talk.com is a moderated site. Moderators will delete and edit posts in an effort to keep the site free of flame wars, insults, crude language, advertising and off-topic replies. Please be polite and helpful in your replies and feel free to seek help without fear of undue criticism.
    If you are a Pro,please understand the assistance you need is only available in the Pro section.
    No this is not like other forums you may be familar with.This forum requires we keep things that could be used for DIY in the Pro area.
    Could have been explained better to start off,but take a breath and look into becoming a
    pro here,it's very worthwhile.
