Results 14 to 18 of 18
Thread: Couple questions
07-27-2008, 04:28 PM #14
- Feb 2007
- 997
Actually, the main reason that I had this done was that I wanted an easy way to monitor what my system is doing. In my former location, the a/c was piped outside. In my present home, the condensate was piped to a french drain in the basement, near the furnace.
It was difficult to get to and there was no way to measure how much condensate was being produced. Now, when I want to see what's going on, I place the outlet into a 2 quart vessel w/calibrations.
As far as the cannister, while not necessary, I thought it would be a good idea environmentally speaking.
AMLast edited by ampulman; 07-27-2008 at 04:45 PM. Reason: no additional info added
07-27-2008, 04:42 PM #15
07-27-2008, 06:53 PM #16
- Jul 2008
- Southeast michigan
- 93
when I use to install we would try and pump them in laundry tubs. If you have a good winter it will freeze up and then the pump will fill and whala no heat.
07-27-2008, 07:16 PM #17
- Jul 2001
- 3,112
Why can't the condensate be discharged into a sewer or septic system? The ph of the condenstae is 3.8 to 4.8 , which is close to that of an orange, which is 3.3 to 4.15. What harm is caused ?
07-27-2008, 07:28 PM #18
The average orange, doesn't contain 5 plus gallons of juice.
Some municipalities, require a neutralizer, some don't.
