Results 14 to 16 of 16
    Quote Originally Posted by Swampfox View Post
    Ive never used one either, totally useless for taking air temperatures, they are surface thermometers!!!
    point one at the sky and see what temperature you get
    I was browsing threw some threads and just had to comment -
    Far to many people use these cheap IR thermometers and have no clue about emissivity. Chances are you are using it for measuring duct temp (you think you are anyway) and metal duct has a very low emissivity so all you are really measuring is the reflected temperature. Even the plastic duct work has a low emissivity and will not be correct.
    I encourage anyone who is using one of these types of meters to wrap a piece of copper pipe with some standard black electrical tape. Run the hot water and measure the part which has tape versus just the copper tube. You may be surprised what you see.
    IR measurements are complicated and there are a lot of variables that come into play for true quantitative data; even for crude qualitative data you need a reasonable understanding of IR theory.
    Also please don't fall into the trap of setting one emissivity and using it for everything with the thinking that the error will cancel out; that couldn't be farther from the truth.
    Lastly, a much more accurate measure of air temp would be to simply hang a T or K type thermocouple into the air stream. Most decent Fluke DMM's allow thermocouple inputs. I don't think anyone here needs RTD accuracy.
    -Chris
    Aug 2008
    Florida
    I think they're extremely useful!!
    If you're hunting a car chase suspect who just lost you in a parking garage and you're trying to determine which vehicle is still smoking hot.
    I use mine on a very limited basis, sometimes to check components inside equipment without taking it all apart. I laugh when I catch someone trying to check SH/SC with a IR temp gun.
    If they wrap the copper with standard scotch black electrical tape which has an emissivity of 0.95 they would get a rather accurate reading. Just aiming it at copper though will result in reading their body or some other reflected temp.
