Results 1 to 8 of 8
    Wilkes-Barre, Pa.
    sub panel question
    hello everyone, I'm curious about something I saw today and I'm not really sure it is safe. can a 2 pole 60 amp and a 2 pole 30 be installed safely in a 60 amp sub panel? thanks in advance for any replies
    Central Maryland
    Quote Originally Posted by blackwater View Post
    Assuming it has a 60 amp breaker-
    safe, yes
    useful, depends.
    -HF
    If the 60 amp box is protected by a 60 amp breaker it can.
    Its just a waste to do it.
    If the 60 amp box is protected by a 60 amp or less. Then it is unsafe.
    Apr 2002
    the manufacturer may have a maximum size branch breaker, and I would suspect this is a physical limitation.
    Your sub panel could be getting back fed through that 60A breaker
    Could be that the 60 amp breaker he is seeing, is the 60 amp main breaker for the sub panel.
    Why is it unsafe
    I'm just a homeower (Electrical Engineer by training, but do software
    these days). And I don't do any big time wiring.
    But I guess I don't see why having a 60 amp 240 V box being protected
    by a smaller breaker (that presumably is one each leg) is unsafe.
    You are saying that a smaller breaker is unsafe while a larger one is safe?
    Won't the box that has the small breaker just be very likely to trip?
    Quote Originally Posted by bobRitchie View Post
    so your saying that a 30 amp is feeding this 60 amp box?
    if so that is fine, the 30 will trip and prtect the circuit.
    but why use a 60 in that box if its being feed by a 30? inless this 60 amp breaker isn't a breaker but a disconnect style of breaker
    just what is this panel going to? i need a better understanding of what is going on in this situation
    Meant to type "Then its not unsafe".
