Results 14 to 21 of 21
    Dec 2006
    Northern VA
    Heat traps on water heaters.... Can't stand them. They cause more call backs than they save in energy.
    Jun 2008
    Quote Originally Posted by EverettsHVAC View Post
    Wasn't recommending you install them yourself. Just make sure the manufacturer has them built in. Many units are coming that way. Just make sure yours is, that way its part of the warranty.
    Dec 2006
    Northern VA
    All new tank type water heaters come with them. We have had more problems with them then they are worth. I really dislike these things if you can't tell...
    Jun 2008
    don't worry the hot water coil thing is out for sure. I wasn't planning on doing anything with the water heater.
    Jun 2008
    Confused which part is the "return drop"?
    another contractor stopped by, he didn't think I need to rebuild the top part (where the two join) of the return. On his chart it shows he has what he need cf??. Nobody seems to know why (see 1 post photo) it has a "flat blocked duct under it" any guesses?
    is the return drop the bottom (photo 1) next to the furnace?
    Huntsville,AL
    what problems have been experienced with 'heat traps' ?
    I installed the thermal antisiphon nipples on my elec HWH some 4y/a & they have worked great!!!
    Ohouse: buy a system which is designed for YOUR house, of good materials & workmanship. Pretend that the present one does not exist, then see what can be salvaged, or just how bad a mismatch. read lots herein.
    The return drop is the vertical section from the furnace to the horizontal duct at the joist.
    Dec 2006
    Northern VA
    Quote Originally Posted by cem-bsee View Post
    The heat traps provided with Rheem and State water heaters really reduce water flow. They look like 1/2" dia inside. We have found on replacements that HO's complain that they aren't getting as much hot water as before. We remove the heat traps and problem is solved.
    Sorry to hijack this thread....
