    Jun 2007
    Darby, PA
    Chlorine damage!
    Sent out for a "water leak from AC" call today at a pool supply company (heavy rains the last couple of days). Payne AHU, two years old. Ductwork dry, condensate trap and tray clean, charge and filters good. Note the corrosion on rook decking above flex duct. Holes are completely through the decking in numerous locations at store. All t-bar grid and diffusers in store corroding due to chlorine in the air from pool chemicals. AHU's replaced 2 years ago because evap coil fins completely disentegrated. Would you trust walking on the roof? Insulated start collar to cover my a** while there.
    Oct 2007
    Milwaukee,WI
    Any metal (especially the return duct) should be polyvinyl/PDC coated anyway.
    It doesn't take long for that stuff to rot out.
    ___________________________
    Chicago is an indian word for stinky!!!!!!
    -supertek65
    Jun 2007
    Darby, PA
    Can only work with the hand that was dealt!
    Denver, CO
    I wish I had the pics I took 7 Years ago of some heat exchangers at a Holiday Inn that supplied their pool area. Man the cholorine is some corrosive stuff. I could litteraly put my fist through parts of the heat exchanger all 3 heat exchangers were done.
    Oct 2007
    Milwaukee,WI
    Quote Originally Posted by ldmth44 View Post
    For sure!
    This was something that should have been addressed when the place was being built...lol.
    -supertek65
