    Feb 2007
    Central NJ
    Pitot tubes for velocity
    Anybody out there in the world take velocity measurements anymore? is there a recommended pitot tube diameter rated for certain size ducts or does any of that stuff matter
    Stafford, Va. USA
    Quote Originally Posted by n-e-w Jerz! View Post
    Hi New Jerz,
    I and a lot of other guys do use a pitot tubes to measure the air velocity pressure to determine air flow.
    The pitot tubes are the same diameter. The diameter may vary from manufacturer to manufacturer. seen one that was 72 inches long but the same diameter as an 18 inch tube.
    Allen
    Feb 2007
    Central NJ
    thanks allen. seems like your the only one out there who would take the time to use this lost art of taking measurements! guess i only have to purchase one pitot tube instead of many.
    Stafford, Va. USA
    HI New Jerz,
    I use the pitot tubes inconjunction with a Shortridge Air Data Meter. The Shortridge can be set to be used with the pitot tube, instead of displaying a difference in pressure (which it will do) it will display velocity in feet per minute. It actually will average the stored velocity readings.
    We do have the inclined manometers, but don't use them because of the Shortridge.
    Allen
    Jun 2001
    Louisville, KY
    Several know how to do it.
    Many have found that mini vanes are more repeatable and more accurate because of the larger opening.
    Feb 2007
    Central NJ
    i'll be using a magnehilic gauge or a testo digital manometer. was surprised at how much a inclined manometer cost. really don't want to buy anymore tools right now (even though i will end up buying something anyhow)...
