Page 4 of 5 FirstFirst 12345 LastLast
Results 40 to 52 of 65
  1. #40
    Jan 2005
    Ok I have read and read this post "In the nearly 10 years I was with Goodman, I've never seen a warranty issue that wasn't caused by the contractor or consumer." and I have to say that I am sorry but it comes off the wrong way. I think that you are saying that in the 10 years that you were with Goodman that there were no problems with Goodman backing their warranties other than those created by the contractor or consumer. I misunderstood that as if you were saying that Goodman was flawless and never had a component fail that was not due to the consumer or contractor. I say again to the person who started this post make sure that the company you deal with gets your equipment from a local supply house (not an online store).
    "It's always controls"
  2. #41
    Jan 2005
    Quote Originally Posted by praha99 View Post
    Just FYI, if you don`t agree with ROBO, he will become very childish and attack your character... call you names.. etc That`s pretty standard operating procedure.
    Just watch I`m next
    They can all be reprogrammed or disassembled.
  3. #42
    Apr 2006
    Chicagoland
    Quote Originally Posted by RoBoTeq View Post
    Why? What are your reasons for this bias? Be specific please.
    ok sure no problem.
    1. Bad designs.
    Downflow boards that get too hot and have the same hot spot on all the bad ones (just one example)
    2. Crappy Bristol compressors on majority of older units
    3. Cheap cabinets
    4. Noisy after a few years due to #3
    5. Warranty a Goodman part at Johnstone, normal wait to get reimbursement: 4 months.
    Others a tad better.
    6. No local technical support (Chicago land area)
    7. Mostly installed by lowest bidder or "friend of a friend" doing side work and other hacks
    8. 90+ furnaces PITA traps
    9. " " no sealed combustion chamber
    10. Same price (for me) as a better quality B series American Standard product.. so why even bother
    11. Horrible reputation (must be because they are so good.. maybe they are just misunderstood lol)
    etc...etc..
    I could say the same about other low end brand but you didn`t ask
    Sorry - yesterday was the deadline for all complaints.
  4. #43
    The goodmans I have installed recently, have a copeland compressor in them. Your reasons for not liking them are a little shallow, but then again, I have kind of a rheem bias myself. Although I sell a lot more of the Amana's lateley, comes with the same copeland scroll the rheem does, and a lot better warranty, also lower price, Just a better all around value for the customer. From a service stand point, it is hard to beat rheems access, everything in the one back compartment, but that is about the only advantage. By the way we recently set 6 goodmans, all in a row on one side of a building, I was actually impressed by how quite they were running,
  5. #44
    Minnesota
    In addition to being quieter than Goodman, the Trane/American Standard has:
    1. Spine fin coil.
    2. All aluminum evaporator coil.
    3. Condensor cabinet that was painted AFTER being stamped.
    This is a short versoion of a much longer list, but thought I'd throw this out there since we've got to 3 pages without anyone noting these obvious differences. And I just dont have the time to explain in detail why Trane is superior.
    White Bear Township, Minnesota
    www.summitheating.com
  6. #45
    Quote Originally Posted by summit View Post
    1. Spine fin coil.
    None of this adds up to better performance. Trane is a good product. But again, a properly installed goodman will perform just as well.
  7. #46
    Coastal North Carolina
    In my opinion, Goodmans are not a bad thing, but not a good one either. Here on the coast of North Carolina, the goodmans are not great in a latent capacity. The design of them are more sensible than latent. But here, they will outlast a Trane by double.
    Trane, god I hate me a Trane. Besides being part specific, meaning you need to go back to the factory for almost every damned part, the coil is a disaster in my mind. Cant repair them when they leak. I condemn probably 30 a year because of the discharge line rubbing a hole in the bottom of the coil where it comes up to the reversing valve. The rotolock fittings here rust out within 3 years and start leaking. The factory will not warranty a compressor change out due to leaking, rusted rotolocks. Perfectly working compressors taken out because you cant get the fittings off of them.
    GMC has had terrible issues with thin copper on their A series air handlers. I love to see one of those with a freon leak. I really dont understand how GMC is still designing equipment with orfices. I dont like orfices at all.
  8. #47
    I dont install a lot of goodmans per say, But do a lot of amana ( slightly higher end goodman) and all get a TXV, it is installer decision. And looking at their charts, you will not get the rated efficiency, without one on most set-ups. Of course that is pretty much all manufacturers.
  9. #48
    Nov 2000
    Eastern PA
    Quote Originally Posted by skwsproul View Post
    I was talking about the statement that you said "In the nearly 10 years I was with Goodman, I've never seen a warranty issue that wasn't caused by the contractor or consumer.". I was in no way trying to attack you but that statement, unless I misunderstood you, seemed a bit bull to me so like you I called it as I saw it so sorry if you got offended. If I am wrong show me the error in my way and I am a big enough man to admit it. As far as "B" stock parts a lot of corporations end up in lawsuit after lawsuit against the companies that supplied their parts for exactly this reason,and I did not say that they did for sure I was just speculating possible reasons that their product line had slipped over the past few years.
    OK now what the hell does knowing you and knowing what you are like have to do with a simple opinion(based on something that you yourself typed) is that some kind of a threat. I do not understand, I do not wish to attack an upstanding member of this site but if we can not speak our opinions what the hell good is this site any ways. Do not for a second take that as if I do not enjoy this site but threats are kind of childish and unnecassary.
    I have read many of your posts and for the most part I have agreed with them but heave forbid I disagree with you once in a while.
    Sorry to the person who started this thread as this is totally off topic.
    Looks like we both misread each others posts as they were intended
    What I meant about contractors or consumers being at fault with warranty issues was the "warranty process", not the part that failed under warranty.
    Sorry for the confusing way I posted that comment.
    ...seek, and ye shall find;..
    Ecclesiastes 10:2 NIV
  10. #49
    Nov 2000
    Eastern PA
    your Goodman glasses are so thick you can`t see past them.
    Again, that comment that I posted was very badly worded. Sorry for the confusion but I certainly did not mean that Goodman has not had warranty issues that were simply manufacturing issues.
  11. #50
    Nov 2000
    Eastern PA
    Just watch I`m next
    I do not. Nuh uhhhh......and how would someone like you know anyway, you commie liberal
  12. #51
    Nov 2001
    east kansas
    Then you agree that this was merely an opinion that has no basis in fact? Is asking someone for a reason for their "opinion" harrassment? Should we all just go; ooohhh and ahhhh because someone makes a comment that a brand is best with absolutely no reason as to why?
    And what does any of this have to do with you? Why must you harrass me when I attempt to obtain proper information rather then mere opinions? See how silly that sounds?
    What does this have to do with me. I'm a member of this board. I've been here only 1 year less than you. I have given specfic reasons why I'd rather not install Goodman products and have lost privledges on this site because of that.
    Beware of advice given by some guy on the Internet.
  13. #52
    Nov 2000
    Eastern PA
    Thank you for taking the time to try to understand my intent. Damned posting makes me sound like I could possibly be an unreasonable person
