Results 1 to 13 of 27
    Phoenix, AZ
    Pop Quiz: Why is this unit leaking into the home?
    This is what happens when I take photos of things OTHER than bad A/C installations:
    Arizona. Photographed: http://community.webshots.com/album/563042864aIFjqw
    Phoenix, AZ
    PS: it's leaking in a very specific way, into a very specific location into the home.
    John Culpepper's Avatar
    John Culpepper is offline CHANGE YOUR EMAIL ADDRESS Professional Member*
    Oct 2007
    Austin Texas
    CO?
    Nemo me impune lacessit.
    How much blood do I have to bathe in to get clean?
    Don't look down on anyone unless you're helping them up.
    Phoenix, AZ
    H2O
    Oct 2007
    Austin Texas
    Quote Originally Posted by rifter1 View Post
    H2O
    There isn't any tee on the condensate line for any future clean out.
    May 2008
    Houston
    No insulation on duct?
    Apr 2003
    Eugene, Oregon
    Hmmmm, your in AZ its 115 degrees out and your pushing some mighty fine cold air through that un-insulated duct. Must be due to the crappy equipment.
    Proud supporter of Springfield Millers and Oregon Ducks.
    Dec 2006
    Las Vegas NV
    Could it be leaking at the T-stat???
    Panama City, FL
    Quote Originally Posted by cotechinvegas View Post
    Break or cut in the t'stat wire drawing the water by capillary action to leak at the thermostat is very possible. Besides look at the ductwork. It's shiny. Shiny stuff don't leak.
    He didn't say whether on not it only leaks when it rains. Plenty of places it shoould leak, though.
    You can't learn a thing with your mouth open.
    Mar 2006
    ?????condensation would be on the outside of the pipe???? drain has a trap, low voltage is run on the outside of the unit. return air seams arent sealed (not that I can see)???? got me, could be a number of things
    Anything worth doing, is worth doing right......the first time!!!
    Denver, CO
    Thats purty, I would have painted it to match the sideing, BTW thats why it's leaking it just needs a fresh coat of pait. Maybe pink to match the pink flamingos in the lawn
    Jun 2007
    Darby, PA
    Supply (round) duct at roofline? Looks like the male end pointing down into the female duct connection at roof line. Are the supports to the round duct nailed/screwed into roof or just free-standing?
    Phoenix, AZ
    Thats one of those dehumidification systems, cause contrary to popular belief it's not always a "Dry Heat"
    I'd say around 40 ST and Broadway
