Thread: Need Bryant Economizer help
07-24-2008, 08:58 PM #1
Ok guys, thrown into a job via national accounts that have all Bryant units on the roof, no literature but they have economizer board with 2- 9 volt batteries on them, I turn the outdoor controller on the economizer down but the damper doesn't move, units won't heat or cool so I know it is an economizer issue.Anyone have troubleshooting literature on these and are the boards junk, I turned the damper worm gear by hand and it moves back to one position so motor moves.
07-24-2008, 09:53 PM #2
- Nov 2004
- 209
how about more info?model/serial #. is it a separate econo board?
AIRFLOW IS CRITICAL
07-24-2008, 10:42 PM #3
Professional Member*
- Jan 2008
- Dallas ,Texas
- 3,504
Man I haven`t seen one of those in years end switches and all huh.
07-25-2008, 06:09 AM #4
- Aug 2002
- manitowoc wisconsin
- 4,687
The boards for those are so costly you should install new micrometal econmizers & forget fixing them.
Take your time & do it right!
07-26-2008, 09:05 AM #5
- May 2006
- 16
Jumpering blue and gray on the economizer molex plug will get you mechanical cooling. The two 9 volt batteries were to shut the damper in the event of a power failure. I agree with the previous post. Too costly to repair.
Go to mechanical cooling(fan cycle,crankcase htr.,etc.) or reinvent the wheel.
