Results 1 to 11 of 11
07-24-2008, 08:17 PM #1
- Mar 2008
- Jackson, NJ
- 176
Tech coming to investigate short cycling - what should he be doing?
Hey Gang,
I have a call into my HVAC installer to check out my system. I have a 1 zone system w/ the stat downstairs. It keeps my upstairs and downstairs at the same temperature (good), but the most it will stay on during a 95+ degree day is 9-10 minutes and the most it will stay on when its 80 or so is 7-8 minutes (not so good). Given what i have learned on this forum I suspect it is short cycling, and after discussing w/ my installer he agreed it warranted a look.
He's coming out early next week. Anything I should know about the visit? What should he be checking? What should I be asking?
Thanks in advance !
07-24-2008, 08:36 PM #2
If the house is the same temp. up and down, what's the problem? How long between cycles? The less it runs, the less YOU pay.......
07-24-2008, 09:04 PM #3
Professional Member*
- Jul 2000
- Northern Wisconsin
- 1,566
The question he should be asking you is: Is the system maintaining a comfortable humidity level in your home?
07-24-2008, 09:12 PM #4
07-24-2008, 09:18 PM #5
- Dec 2006
- Dallas
- 189
on a 95F day, 9-10 minutes ON, how long is it OFF? At what temp is the Thermostat set to? On an 80F day, 7-8 minutes ON, how long is it OFF?but the most it will stay on during a 95+ degree day is 9-10 minutes and the most it will stay on when its 80 or so is 7-8 minutes (not so good).
In one full cycle, What is the highest point and lowest point your thermostat reads? And yes... how is the humidity indoors?
07-24-2008, 09:26 PM #6
He should be checking the humidity.
Also the air flow. He may be able to slow the blower if your humidity is higher then it should be.
He should be checking the CPH setting of your stat. Shouldn't be set higher then 3 CPH.
When we had our 98* outdoor temps, my unit ran 6 hours with out shutting off.
When its 90 outside it runs around ½ an hour.
And its a little over sized.
07-25-2008, 09:18 AM #7
- Mar 2008
- Jackson, NJ
- 176
My system doesn't even run a hour to bring the temperature down 2 degrees.
My humidity upstairs is around 55% when my stat is set to 74. Is that normal?
My stat is set to 3CPH. It seems like my system runs for 8-10 mins then idles for 10 mins. I THINK that would be 3 CPH performance right? I haven't paid enough attention to how it behaves when its only 80 outside however.
Since my system is a heat pump too, I just want to make sure its not going to prematurely konk out on me.
Also, I'm a little concerned b/c once it gets cold and the system calls for my backup propane furrnace, I have a feeling its going to get real hot real quick given its easier to heat then it is to cool. If I can maintain 74 degrees when its almost 100 out while running for only 10 minutes, I almost think I'm going to have a blast furnace when its 30 degrees !!!!
07-25-2008, 09:51 AM #8
Sounds a bite over sized for cooling.
If you have a VS blower, he can set it to 350 CFM per ton, that should help some.
Depending on which stat you have. He can set it to a more aggressive coolings algorthym.
That will make it over shoot set temp, and cause longer off cycles.
A larger HP allows you to have a lower balance point temp. So you may end up with better heating bills then anticipated.
You got the 2 stage LP furnace right?
07-25-2008, 10:10 AM #9
- Mar 2008
- Jackson, NJ
- 176
07-25-2008, 10:29 AM #10
He can probably slow the blower.
07-29-2008, 09:28 AM #11
- Mar 2008
- Jackson, NJ
- 176
