Results 1 to 7 of 7
    Chapel hill nc.
    One ton ducted heat pump
    I am Quoting a heat pump for a second floor addition that is 500 square feet with 4 separate rooms. I need to find a system that can be ducted that is between 9000 and 12000 btu's. I have seen the fujitsu concealed unit and it looks like I could put a return and supply on it but the website does not have the install instructions. Has anyone on here ever done this. Any constructive advice would be appreciated.
    Central Maryland
    Quote Originally Posted by brybo nc View Post
    If you are going with duct work, both Goodman and York have 1.5 ton systems.
    Another option is to get a mini-split system with multiple indoor units on one outdoor unit, for example, this Fujitsu.
    http://www.fujitsugeneral.com/multi.htm
    I have experience with none of these.
    -HF
    Chapel hill nc.
    I have used the Fujitsu ductless units before and really like them. I have talked to the contractor and we both agree that they would not be ideal in this application. I see that York has a one ton condenser but no one ton air handler. Any more ideas?
    The York AHP 2 ton blower can be set for a 1 ton condenser no problem.
    But, the York 1 ton condenser is just that, an A/C condenser, not a HP.
    Dankin has ducted units.
    Chapel hill nc.
    I just went on the Daiken website and they seem to have a 9000 and a 1200BTU ducted heat pump. have any of you guys used their ducted systems?
    Mar 2001
    North Carolina
    Ge Zoneline AZ75H12DAC is a 1 ton self contained heat pump that is duct able.
    we have used these a couple times and all worked out great.
    http://www.geappliances.com/products...ata_manual.pdf
    Chapel hill nc.
    Quote Originally Posted by obxtech View Post
    That might work for this if it had a remote condenser. Thank you for the reply
