    Oct 2005
    Problems with 13 Seer Goodman Heat Pump
    This is a new Install.
    Running a Low Delta Temp across Evap Coil.10 Degrees.
    Superheat stays at 10 Degrees at Compressor--added more charge --No Results--Let some Charge out--Superheat never Changes--COMPLAINT--Not Cooling effectively--Need 15 -18 Degrees across coil--Any Suggestions??
    Did you replace the entire system?
    And why would you post this in wall of shame...why not in the technical section of the pro forums?
    Apr 2003
    Eugene, Oregon
    Is this a 410a system? If so, did you install a TXV?
    Proud supporter of Springfield Millers and Oregon Ducks.
    Oct 2005
    Thanks--I have reposted--Yes--Full replacement.
    Have a Great Day!!
