    Jun 2007
    AC Unit Running All The Time Data Captured...
    Hopefully someone can help me troubleshoot my problem. My Carrier unit runs all the time during the day and sometimes falls behind keeping up with the set point on my T-Stat.
    Details listed below:
    4 Ton Single Zone System made by Carrier and installed in 1996
    Single Family Home 1975 Sq Ft two story cathedral ceilings
    Today’s Readings at 5:00 PM
    Oustide Air Temp 80 Degrees
    Suction Temp At Condenser – 59.2 Degrees
    High SideTemp At Condenser – 83.8 Degrees
    Suction Pressure – 66 psi.
    High Side Pressure – 255 psi.
    R-22 Freon
    I calculate my superheat at 20 Degrees
    This evening my return temp at the return grill was 64 degrees and the supply temp at a register was 56 degrees. Only 8 degrees differential
    Is this unit low on Freon? Or is there something else going on?
    Any help would be greatly appreciated.
    George
    Nov 2001
    Seattle, WA
    Quote Originally Posted by GeorgeCJ View Post
    R-22 Freon
    So your house is at 64 degrees?
    - Alexis de Toqueville, 1835
    Western NC
    R-22 Freon
    George
    Your other thread was already closed.
    THIS IS NOT A DIY FORUM.
    Call a professional.
    Do not post it again.
    Illinois
    Your last post was closed for obvious reason...no more or you'll be locked....out.
