    Richmond, VA
    Lightbulb Thoughts on Replacing the Heat Pump (Outdoor Unit) Flowrater to TXV
    I am going to replace a leaking (Goodman) flowrater type indoor coil with a new direct replacement Coil with a TXV, which is also from Goodman. Since I'll have the system opened up, I've thought about also replacing the Flowrater on outdoor coil (12 seer) heat pump with possibly a universal type TXV kit. (No kit is available from Goodman to upgrade the outdoor unit with a TXV.)
    Does anyone believe that it is worth the trouble of trying to change the outdoor unit's flowrater with a TXV?
    Thanks in advance for your response!
    Todd
    Nope.
    The outdoor TXV doesn't run the same SH as a TXV for an indoor coil.
    Much more headach then it is worth.
    Fort Worth, TX
    Indoor TXV needs to be for heat pump duty (built-in check valve).
    Richmond, VA
    I'll take your advice and keep the job simple and just replace the indoor coil. And yes, I am planning on getting the bi-directional check valve (heat pump) type TXV.
    Thanks for your response beenthere and shophound!
