Results 1 to 7 of 7
Thread: HVAC confusion
    Confused HVAC confusion
    Question for the pros!!
    I have hired a tech. to install a new 2 ton cond. unit and a new 2 ton a-coil. I know that he has tested the line sets and evac. them, by the way he also has had the test on for not only hours but days. The problem he is having is that when he goes to charge the unit with freon he can't get the liquid side pressure up to where it needs to be. He claims it should be around 65 and it only will go up to like 18. Any ideas?
    Yeah....Hire someone else who knows what they are doing.
    Get a better tech.
    We're not allowed to give DIY advise on this site.
    Your tech may be a installer, but he isn't a service tech.
    Hopefully this isn't a unit you bought yourself.
    need more information to help
    suction pressure head pressure line temperature
    make sure you dont have air flow problem
    Arizona
    Quote Originally Posted by bergmw1 View Post
    Did he supply the equipment or did you?
    Is he a contractor or a moonlighter?
    Ohio
    You get what you pay for in this industry....sounds like you went bottom of the barrel
    I need a new signature.....
