Results 1 to 9 of 9
Thread: ???
    I'm going to connect used (working) but empty compressor...question - haw to charge it...it's spouse to be running prior to do it??
    This is not a DIY site. Please read the rules, Thank you.
    If your in the trade. You need to get help to do this. As you don't have the experience needed.
    probably as many as you get enough expirience....
    Quote Originally Posted by lysy View Post
    What? Couldnt make heads or tails of that comment. Any how , do you even know if it is the correct capacity for your home or current Evaporator set-up, why used equipment? You need to hire someone to do this, it sounds like the water has gotten pretty deep already.
    I don't know what he's trying to say either.
    everything is paired correctly(2.5 ton) the problem is never work before with empty compressor(never charge the empty one) and work is for my friend(he got them from somewhere to save some $$$$...)
    Well. your friend should get someone that knows how to do this.
    Not someone that doesn't.
    Thats not meant to insult you.
    We all started out not knowing what we were doing also.
    But swapping out compressors, is not a beginners task.
    Nor will you get help here. As this is not a DIY site. Please read the rules, Thank you.
    Even if your in the trade, we don't give out technical advise in the open forums.
    Someone elses back yard perhaps?
    Illinois
