Thread: ???
    hi what,s wrong??? pressure in both lines is equal and compressor draw about 3.5Amp, any suggestions?? thank you
    Virginia
    that compressor is probably dead time for a new one or new system but call your service company to check it
    Virginia
    it sounds like it running but not pumping
    Bye Bye valves
    Massachusetts
    Make the call. You're gonna need a pro.
