Results 1 to 13 of 16
    Flexible gas line mounted to Water Heater
    Just wondering if it is bad to have a flexible gas line mounted to the water heater with metal brackets and screws. I had a new furnace and central A/C put in and everything looks great. The water heater and gas line was in the way so they moved it and reattached with a flexible gas line. Is it bad to have screws with brackets right into the water heater? Kind of surprised me a little. Thanks
    Teddy
    Feb 2007
    Government base in the woods.
    Teddy,
    We need some pictures of the unit in question.
    "Here in Carolina We Get-R-Done"
    Pictures
    Teddy
    Thats CSST, its legal.
    The screws in the water heater jacket don't look good. But as long as the screws aren't 1", they aren't hurting anything.
    But, your water heater needs the Temperture Pressure Relief valve piped to the floor.
    Massachusetts
    The product used is technically not a flex line, which in most jurisdictions is limited to 3-feet. What was used is called corregated stainless steel and again, depending on the jurisdiction, can be used in the fashion it was. As a matter of professionalism, we normally hard pipe up to the ceiling and adapt to CSS from there. But that's just our company preferrence and not a code thing.
    Although the screw are probably not long enough to hit tank, that is still an idiot manuever.
    When I noticed it I was a little worried. Fortunitly my water heater has 2" insulation around the tank. Anyone ever seen anything like it?
    Teddy
    Chicago IL
    can you show pictures where the csst feeds off the black iron gas line? and some of the csst running up near the flue.
    Sorry Fenian, my camera battery died. Ill get some more pics later. The pipe I am not concerend about so much, just the screws in the tank.
    beenthere: Whats involved in setting up the Temperture Pressure Relief?
    Needs piped down to the floor for safety.
    If it were to open, and leave out 210°F water, your skin wouldn't hold up.
    Toledo, Ohio, United States
    Twilli says now that is sweet
    No Heat No Cool You need Action Fast
    Jun 2008
    Sacramento
    Speaking of Water Heater Installs...
    Ran across this while house-hunting...
    http://www.idxcentral.com/images/mls...68581_10_n.jpg
    You like?
    Jul 2000
    Northern Wisconsin
    Quote Originally Posted by oldheathen View Post
    You like?
    ROFLMAO ....... all it needs is arms and hat and a big happy face on it!
