Results 14 to 23 of 23
    Nov 2001
    Moose Jaw, Saskatchewan, Canada Occupation:Interprovincial Plumber, Commercial Gasfitter Interests:
    SS can rot out pretty quick if something goes wrong inside.
    The OP can become a millionaire ovcer night if he buys the winning lottery ticket.
    Noel.
    How many Aluminum block mod/com boilers have you been involed with that dissolved? (not just heard about)
    I know of three. Also know of SS. Not enough attention is paid to water quality.
    I love my job, but paydays Thursday
    Jan 2002
    New Hampshire
    What I see
    I can't elaborate, but what I've seen is in the lab of a boiler manufacturer.
    Let's just say that it didn't even have a model number, yet.
    How many mod-cons do you install and service in a year?
    Just asking.
    Noel
    Quote Originally Posted by rich pickering View Post
    The area I'll be moving to has well water. Does that make a difference either way? Can I test the water periodically myself?
    Barely Half a dozen some years. 10 or 12 another. (If I was better salesman, it would be more)
    I have Ultras in both commercial and resi applications
    Going on 7th or 8th year for the second oldest Ultra I installed.
    The oldest the block was replaced because the freeze plugs started leaking.
    That was on city water.
    Got some on well water.
    Have heard people many times, say aluminum won't hold up.
    But, everybody I know personally that says that. Has never seen it himself.
    Or knows anything about the history of the install.
    I have a couple Pinacles in also, not vert impressed with them. Just one guy can carry them easier.
    The water PH should be checked before installation.
    And yearly.
    Jan 2002
    New Hampshire
    Best advice, yet
    I heartily agree on testing water in all boilers annually; at LEAST check the pH.
    Noel
    Your hydronic piping can be reused to an extent. (minor alterations)
    What alterations should I expect regarding the piping?
    Piped up as primary secondary piping.
    Ensures proper water flow through the boiler, to protect it.
    BUDERUS
    GB-142 95 % effecient
    Much Better then the Ultra
    JMO
    Quote Originally Posted by dismas66 View Post
    BUDERUS
    JMO
    I've been looking at the GB-142. I like the fact that it comes with a manifold for quicker installation. However, I'm concerned about the fact that it's wall mount only. I was hoping to replace my oil boiler which is in the middle of the room, next to the fireplace. I wanted to keep the same location to reduce the amount of plumbing to be done.
    Can the GB-142 be hung on my chimney?
