Results 1 to 13 of 16
    Jun 2008
    Arizona
    Suction and Discharge Lines in the ground!!
    I serviced a 5 ton split unit that was about 10 years old. The suction line and liquid line out of the house to the condensor runs into the ground and then using three 90 degree fittingsthey lines curl around and connect to the compressor. The air handler is in the attic and is all the way on the other side of the house.
    Why would someone install those lines like that?
    I'm thinking of removing those bends and reconnecting with a gentle bend both those lines.
    Anyone have any thoughts on this subject.
    Sol
    Lancaster PA
    Need pics.
    Perhaps trying to prevent trip hazzard.
    Thye wanted to keep easy access to teh service panel.
    Dec 2006
    Dallas
    Do you mean underground?
    Western NC
    Yes....linesets can run underground..
    Need pics for the rest.
    Austin, TX
    I have a customer that has a 7.5 ton split a/c, and a 4 ton split a/c that
    have the linesets buried for over 114 feet. Units are in the basement.
    Systems have worked very well. The 7.5 ton system is 14 years old, and
    the 4 ton is 20 years old, maybe older. I did just replace the compressor
    in the 4 ton unit, but only because a weld in the compressor leaked out
    the oil.
    mesa arizona
    Thumbs up yo
    hey sol whats goin on?? where in az ru located ?? u do commerc. or resident. work??? im in east valley....but do commerc work in phoenix
    Jun 2008
    Arizona
    Work in Phoenix and looking for hvac work , going to school in mornings
    Houston, Texas
    I have a customer with the same setup. Both lineset go under a driveway and the building slab the up to the 2nd floor. Because the lines are 7/8" and 3/8" all the way (2 - 5 tons), they run very low suction pressures. This is a light commercial building with plenty of people and servers (heat source). They needs a/c year round and when it's cool outside they freeze up on occassion.
    Minor problems, but to correct it you would have to tear out the driveway and tunnel underneath.
    mesa arizona
    Confused yo
    theres plenty of work shorthanded .. go to supplyhouses..u will seee plenty of numbers...i do commercial myself
    mesa arizona
    Unhappy yo
    where do u go to school rsi or uti????gateway college
    Jun 2008
    Arizona
    I found out why the lines were buried ! It was to quieten the lines . That's what the home owner told me.
    Jun 2008
    Arizona
    RSI
    What is the suction pressure?
    What is it at the evaporator? (probably no port there)
    What size suction line and what tonnage system?
    How much superheat?
    If there is a huge pressure drop in the suction line the compressor is working harder.
    Will you increase the net refrigeration effect enough to offset the cost of working on the system?
